Retrieve diagnostic operation results for a MetroCluster configuration
Retrieves the results of a completed diagnostic operation for a MetroCluster configuration to assess system health and performance.
HTTP method and endpoint
GET /cluster/metrocluster/diagnostics
Introduced in
ONTAP 9.8
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
aggregate |
cluster |
config-replication |
connection |
interface |
node |
volume |
"aggregate": {
"details": [
"aggregate": {
"href": "/api/resourcelink"
"name": "aggr1",
"checks": [
"additional_info": {
"code": "string",
"message": "string"
"name": "mirror_status",
"result": "string"
"cluster": {
"name": "cluster1",
"node": {
"name": "node1",
"timestamp": "2016-03-10 17:35:16 -0500",
"volume": {
"name": "volume1",
"state": "string",
"summary": {
"code": "string",
"message": "string"
"cluster": {
"details": [
"aggregate": {
"name": "aggr1",
"checks": [
"code": "string",
"message": "string"
"result": "string"
"cluster": {
"name": "cluster1",
"node": {
"name": "node1",
"volume": {
"name": "volume1",
"state": "string",
"summary": {
"code": "string",
"message": "string"
"config-replication": {
"state": "string",
"summary": {
"code": "string",
"message": "string"
"timestamp": "2016-03-14 18:35:16 -0400"
"connection": {
"details": [
"cluster": {
"name": "cluster1",
"connections": [
"destination_address": "string",
"partner": {
"node": {
"name": "node1",
"type": "string"
"port": "string",
"result": "string",
"source_address": "string",
"state": "string"
"node": {
"name": "node1",
"state": "string",
"summary": {
"code": "string",
"message": "string"
"interface": {
"state": "string",
"summary": {
"code": "string",
"message": "string"
"node": {
"details": [
"aggregate": {
"name": "aggr1",
"checks": [
"code": "string",
"message": "string"
"result": "string"
"cluster": {
"name": "cluster1",
"node": {
"name": "node1",
"volume": {
"name": "volume1",
"state": "string",
"summary": {
"code": "string",
"message": "string"
"volume": {
"details": [
"aggregate": {
"name": "aggr1",
"checks": [
"code": "string",
"message": "string"
"result": "string"
"cluster": {
"name": "cluster1",
"node": {
"name": "node1",
"volume": {
"name": "volume1",
"state": "string",
"summary": {
"code": "string",
"message": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2426405 |
MetroCluster is not configured in cluster "cluster". Run "metrocluster show" to verify both the local and the remote clusters are configured as MetroCluster, and then try the command again. |
2432856 |
MetroCluster diagnostics result is not available. Use the REST API GET method on "/api/cluster/metrocluster/operations?type=check&fields=*" for more information. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
aggregate
Aggregate
_links |
name |
string |
uuid |
string |
additional_info
Additional information or recovery steps to take on this component.
code |
string |
Argument code |
message |
string |
Message argument |
metrocluster_diag_check
Generic object which can be used for various components which holds details of the checks of a component.
additional_info |
Additional information or recovery steps to take on this component. |
name |
string |
Name of type of diagnostic operation run for the component. |
result |
string |
Result of the diagnostic operation on this component. |
cluster
_links |
name |
string |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
metrocluster_diag_details
aggregate |
Aggregate |
checks |
array[metrocluster_diag_check] |
Collection of MetroCluster checks done for component. |
cluster |
node |
timestamp |
string |
Time check was done. |
volume |
summary
Additional information or recovery steps to take.
code |
string |
Argument code |
message |
string |
Message argument |
aggregate
details |
array[metrocluster_diag_details] |
Display details of the MetroCluster check for aggregates. |
state |
string |
Status of diagnostic operation for this component. |
summary |
Additional information or recovery steps to take. |
timestamp |
string |
Time of the most recent diagnostic operation for this component |
cluster
details |
Display details of the MetroCluster check for clusters. |
state |
string |
summary |
timestamp |
string |
config-replication
state |
string |
summary |
timestamp |
string |
partner
node |
type |
string |
metrocluster_diag_connection
destination_address |
string |
partner |
port |
string |
result |
string |
source_address |
string |
state |
string |
metrocluster_diag_connection_details
cluster |
connections |
array[metrocluster_diag_connection] |
node |
connection
details |
Display details of the MetroCluster check for connections. |
state |
string |
summary |
timestamp |
string |
interface
state |
string |
summary |
timestamp |
string |
node
details |
Displays details of the MetroCluster check for nodes. |
state |
string |
summary |
timestamp |
string |
volume
details |
Display details of the MetroCluster check for volumes. |
state |
string |
summary |
timestamp |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
