Retrieve diagnostic operation results for a MetroCluster configuration
GET /cluster/metrocluster/diagnostics
Introduced In: 9.8
Retrieves the results of a completed diagnostic operation for the MetroCluster configuration.
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
Status: 200, Ok
| Name | Type | Description |
aggregate  |
cluster  |
config-replication  |
connection  |
interface  |
node  |
volume  |
  "aggregate": {
    "details": [
        "aggregate": {
              "href": "/api/resourcelink"
          "name": "aggr1",
        "checks": [
            "additional_info": {
              "code": "string",
              "message": "string"
            "name": "mirror_status",
            "result": "string"
        "cluster": {
          "name": "cluster1",
        "node": {
          "name": "node1",
        "timestamp": "2016-03-10 17:35:16 -0500",
        "volume": {
          "name": "volume1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "cluster": {
    "details": [
        "aggregate": {
          "name": "aggr1",
        "checks": [
              "code": "string",
              "message": "string"
            "result": "string"
        "cluster": {
          "name": "cluster1",
        "node": {
          "name": "node1",
        "volume": {
          "name": "volume1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "config-replication": {
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
    "timestamp": "2016-03-14 18:35:16 -0400"
  "connection": {
    "details": [
        "cluster": {
          "name": "cluster1",
        "connections": [
            "destination_address": "string",
            "partner": {
              "node": {
                "name": "node1",
              "type": "string"
            "port": "string",
            "result": "string",
            "source_address": "string",
            "state": "string"
        "node": {
          "name": "node1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "interface": {
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "node": {
    "details": [
        "aggregate": {
          "name": "aggr1",
        "checks": [
              "code": "string",
              "message": "string"
            "result": "string"
        "cluster": {
          "name": "cluster1",
        "node": {
          "name": "node1",
        "volume": {
          "name": "volume1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "volume": {
    "details": [
        "aggregate": {
          "name": "aggr1",
        "checks": [
              "code": "string",
              "message": "string"
            "result": "string"
        "cluster": {
          "name": "cluster1",
        "node": {
          "name": "node1",
        "volume": {
          "name": "volume1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734  |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.  |
2426405  |
MetroCluster is not configured in cluster "cluster". Run "metrocluster show" to verify both the local and the remote clusters are configured as MetroCluster, and then try the command again.  |
2432856  |
MetroCluster diagnostics result is not available. Use the REST API GET method on "/api/cluster/metrocluster/operations?type=check&fields=*" for more information.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
aggregate
Aggregate
_links  |
name  |
string  |
uuid  |
string  |
additional_info
Additional information or recovery steps to take on this component.
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
metrocluster_diag_check
Generic object which can be used for various components which holds details of the checks of a component.
additional_info  |
Additional information or recovery steps to take on this component.  |
name  |
string  |
Name of type of diagnostic operation run for the component.  |
result  |
string  |
Result of the diagnostic operation on this component.  |
cluster
_links  |
name  |
string  |
uuid  |
string  |
node
_links  |
name  |
string  |
uuid  |
string  |
volume
_links  |
name  |
string  |
The name of the volume. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
metrocluster_diag_details
aggregate  |
Aggregate  |
checks  |
array[metrocluster_diag_check]  |
Collection of MetroCluster checks done for component.  |
cluster  |
node  |
timestamp  |
string  |
Time check was done.  |
volume  |
summary
Additional information or recovery steps to take.
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
aggregate
details  |
array[metrocluster_diag_details]  |
Display details of the MetroCluster check for aggregates.  |
state  |
string  |
Status of diagnostic operation for this component.  |
summary  |
Additional information or recovery steps to take.  |
timestamp  |
string  |
Time of the most recent diagnostic operation for this component  |
cluster
details  |
Display details of the MetroCluster check for clusters.  |
state  |
string  |
summary  |
timestamp  |
string  |
config-replication
state  |
string  |
summary  |
timestamp  |
string  |
partner
node  |
type  |
string  |
metrocluster_diag_connection
destination_address  |
string  |
partner  |
port  |
string  |
result  |
string  |
source_address  |
string  |
state  |
string  |
metrocluster_diag_connection_details
cluster  |
connections  |
array[metrocluster_diag_connection]  |
node  |
connection
details  |
Display details of the MetroCluster check for connections.  |
state  |
string  |
summary  |
timestamp  |
string  |
interface
state  |
string  |
summary  |
timestamp  |
string  |
node
details  |
Displays details of the MetroCluster check for nodes.  |
state  |
string  |
summary  |
timestamp  |
string  |
volume
details  |
Display details of the MetroCluster check for volumes.  |
state  |
string  |
summary  |
timestamp  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
