Retrieve diagnostic operation results for a MetroCluster configuration
Obtains completed diagnostic operation results for the MetroCluster configuration to analyze system performance and troubleshoot issues.
HTTP method and endpoint
GET /cluster/metrocluster/diagnostics
Introduced in
ONTAP 9.8
Usage notes
Retrieves the results of a completed diagnostic operation for the MetroCluster configuration.
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
aggregate |
cluster |
config-replication |
connection |
interface |
node |
volume |
"aggregate": {
"state": "string",
"summary": {
"code": "string",
"message": "string"
"timestamp": "2016-03-10T14:35:16-08:00"
"cluster": {
"state": "string",
"summary": {
"code": "string",
"message": "string"
"config-replication": {
"state": "string",
"summary": {
"code": "string",
"message": "string"
"timestamp": "2016-03-14T14:35:16-08:00"
"connection": {
"state": "string",
"summary": {
"code": "string",
"message": "string"
"interface": {
"state": "string",
"summary": {
"code": "string",
"message": "string"
"node": {
"state": "string",
"summary": {
"code": "string",
"message": "string"
"volume": {
"state": "string",
"summary": {
"code": "string",
"message": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2427132 |
MetroCluster is not configured on this cluster. |
2432856 |
MetroCluster diagnostics result is not available. Use the REST API GET method on "/api/cluster/metrocluster/operations?type=check&fields=*" for more information. |
summary
Additional information or recovery steps to take.
code |
string |
Argument code |
message |
string |
Message argument |
aggregate
state |
string |
Status of diagnostic operation for this component. |
summary |
Additional information or recovery steps to take. |
timestamp |
string |
Time of the most recent diagnostic operation for this component |
cluster
state |
string |
summary |
timestamp |
string |
config-replication
state |
string |
summary |
timestamp |
string |
connection
state |
string |
summary |
timestamp |
string |
interface
state |
string |
summary |
timestamp |
string |
node
state |
string |
summary |
timestamp |
string |
volume
state |
string |
summary |
timestamp |
string |
