Retrieve diagnostic operation results for a MetroCluster configuration
GET /cluster/metrocluster/diagnostics
Introduced In: 9.8
Retrieves the results of a completed diagnostic operation for the MetroCluster configuration.
component |
string |
query |
False |
MetroCluster diagnostic component name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
components |
array[metrocluster_diag_component] |
"components": [
"aggregates": [
"aggregate": {
"href": "/api/resourcelink"
"name": "aggr1",
"check": "string",
"cluster": {
"name": "cluster1",
"details": "string",
"node": {
"name": "node1",
"state": "string"
"clusters": [
"check": "string",
"cluster": {
"name": "cluster1",
"state": "string",
"timestamp": "2016-03-10T14:35:16-08:00"
"connections": [
"cluster": {
"name": "cluster1",
"config_error_info": "string",
"config_state": "string",
"destination_address": "10.10.10.7",
"dr_group": {
"id": 0
"home_port": "string",
"mtu_error_details": "string",
"node": {
"name": "node1",
"partner_cluster": {
"name": "cluster1",
"partner_node": {
"name": "node1",
"partner_type": "string",
"ping_error_details": "string",
"relationship_type": "string",
"source_address": "10.10.10.7",
"state": "string",
"storage_error_details": "string"
"lifs": [
"check": "string",
"cluster": {
"name": "cluster1",
"lif": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"state": "string",
"vserver": {
"name": "svm1",
"nodes": [
"check": "string",
"cluster": {
"name": "cluster1",
"node": {
"name": "node1",
"state": "string"
"state": "string",
"timestamp": "2016-03-10T14:35:16-08:00",
"type": "string",
"volumes": [
"check": "string",
"state": "string",
"volume": {
"name": "volume1",
"vserver": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2427132 |
MetroCluster is not configured on this cluster. |
href |
string |
_links
self |
aggregate
Aggregate
_links |
name |
string |
uuid |
string |
cluster
_links |
name |
string |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
metrocluster_diag_component_aggr
aggregate |
Aggregate |
check |
string |
Type of check run on the component. |
cluster |
details |
string |
Additional information or recovery steps to take. |
node |
state |
string |
Status of the diagnostic operation on this component. |
metrocluster_diag_component_cluster
check |
string |
cluster |
details |
string |
state |
string |
timestamp |
string |
Time of the most recent check. |
dr_group
DR group reference.
id |
integer |
DR Group ID |
partner_cluster
Partner Cluster information
_links |
name |
string |
uuid |
string |
partner_node
Partner Node information
_links |
name |
string |
uuid |
string |
metrocluster_diag_component_connection
cluster |
config_error_info |
string |
Configuration error information. |
config_state |
string |
Configuration state of the connection. |
destination_address |
string |
Destination IP Address |
dr_group |
DR group reference. |
home_port |
string |
Home port |
mtu_error_details |
string |
Additional information or recovery steps associated with mtu size errors. |
node |
partner_cluster |
Partner Cluster information |
partner_node |
Partner Node information |
partner_type |
string |
Partner's assigned role in a DR group. |
ping_error_details |
string |
Additional information or recovery steps associated with ping errors. |
relationship_type |
string |
This node's assigned role in a DR group. |
source_address |
string |
Source IP Address |
state |
string |
Status of diagnostic operation on this component. |
storage_error_details |
string |
Additional information or recovery steps associated with storage errors. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
lif
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
vserver
_links |
name |
string |
The name of the SVM. |
uuid |
string |
metrocluster_diag_component_lif
check |
string |
cluster |
details |
string |
lif |
state |
string |
vserver |
metrocluster_diag_component_node
check |
string |
cluster |
details |
string |
node |
state |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
metrocluster_diag_component_volume
check |
string |
details |
string |
state |
string |
volume |
vserver |
aggregates |
This object contains details of the aggregate checks when the state associated with the check is "warning". |
clusters |
This object contains details of the cluster checks when the state associated with the check is "warning". |
connections |
This object contains details of the connections checks the state associated with the check is "warning". |
details |
string |
lifs |
This object contains details of the interface checks when the state associated with the check is "warning". |
nodes |
This object contains details of the node checks when the state associated with the check is "warning". |
state |
string |
Status of diagnostic operation for this component. |
timestamp |
string |
Time of the most recent diagnostic operation for this component |
type |
string |
volumes |
This object contains details of the volume checks when the state associated with the check is "warning". |
