Retrieve import operation status for CIFS local users, groups, and group memberships
GET /protocols/cifs/users-and-groups/bulk-import/{svm.uuid}
Introduced In: 9.11
Retrieves information about the import operation status of the CIFS local users, groups, and group memberships.
Related ONTAP commands
vserver cifs users-and-groups import get-status
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
detailed_status  |
elements_ignored  |
integer  |
Number of elements ignored.  |
elements_imported  |
integer  |
Number of elements successfully imported.  |
import_uri  |
state  |
string  |
Operation status.  |
status_uri  |
svm  |
      "href": "/api/resourcelink"
  "detailed_status": {
    "code": "6684732",
    "message": "string"
  "import_uri": {
    "path": "http://web.sample.com/web1/file1.7z"
  "state": "string",
  "status_uri": {
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
detailed_status
code  |
string  |
Code corresponding to the import status failure.  |
message  |
string  |
Detailed description of the import status.  |
import_uri
path  |
string  |
URI from which to load the input file containing the CIFS local users and groups. The file must be encrypted using the 7zip utility. URI can be FTP or HTTP.  |
status_uri
path  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
