REST API reference
Retrieve import operation status for CIFS local users, groups, and group memberships
Accesses the status of import operations for CIFS local users, groups, and group memberships. This helps you monitor and verify the progress and outcome of these import tasks.
HTTP method and endpoint
GET /protocols/cifs/users-and-groups/bulk-import/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Retrieves information about the import operation status of the CIFS local users, groups, and group memberships.
  • vserver cifs users-and-groups import get-status
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
detailed_status
detailed_status
elements_ignored
integer
Number of elements ignored.
elements_imported
integer
Number of elements successfully imported.
import_uri
import_uri
state
string
Operation status.
status_uri
status_uri
svm
svm
      "href": "/api/resourcelink"
  "detailed_status": {
    "code": "6684732",
    "message": "string"
  "elements_ignored": 0,
  "elements_imported": 0,
  "import_uri": {
    "path": "http://web.sample.com/web1/file1.7z"
  "state": "string",
  "status_uri": {
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
detailed_status
code
string
Code corresponding to the import status failure.
message
string
Detailed description of the import status.
import_uri
path
string
URI from which to load the input file containing the CIFS local users and groups. The file must be encrypted using the 7zip utility. URI can be FTP or HTTP.
status_uri
path
string
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
