Retrieve import operation status for CIFS local users, groups, and group memberships
GET /protocols/cifs/users-and-groups/bulk-import/{svm.uuid}
Introduced In: 9.11
Retrieves information about the import operation status of the CIFS local users, groups, and group memberships.
Related ONTAP commands
vserver cifs users-and-groups import get-status
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
detailed_status |
elements_ignored |
integer |
Number of elements ignored. |
elements_imported |
integer |
Number of elements successfully imported. |
import_uri |
state |
string |
Operation status. |
status_uri |
svm |
"href": "/api/resourcelink"
"detailed_status": {
"code": "6684732",
"message": "string"
"elements_ignored": 0,
"elements_imported": 0,
"import_uri": {
"path": "http://web.sample.com/web1/file1.7z"
"state": "string",
"status_uri": {
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
detailed_status
code |
string |
Code corresponding to the import status failure. |
message |
string |
Detailed description of the import status. |
import_uri
path |
string |
URI from which to load the input file containing the CIFS local users and groups. The file must be encrypted using the 7zip utility. URI can be FTP or HTTP. |
status_uri
path |
string |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
