Retrieve import operation status for CIFS local users, groups, and group memberships
Accesses the status of import operations for CIFS local users, groups, and group memberships. This helps you monitor and verify the progress and outcome of these import tasks.
HTTP method and endpoint
GET /protocols/cifs/users-and-groups/bulk-import/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Retrieves information about the import operation status of the CIFS local users, groups, and group memberships.
Related ONTAP commands
vserver cifs users-and-groups import get-status
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
detailed_status |
elements_ignored |
integer |
Number of elements ignored. |
elements_imported |
integer |
Number of elements successfully imported. |
import_uri |
state |
string |
Operation status. |
status_uri |
svm |
"href": "/api/resourcelink"
"detailed_status": {
"code": "6684732",
"message": "string"
"elements_ignored": 0,
"elements_imported": 0,
"import_uri": {
"path": "http://web.sample.com/web1/file1.7z"
"state": "string",
"status_uri": {
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
detailed_status
code |
string |
Code corresponding to the import status failure. |
message |
string |
Detailed description of the import status. |
import_uri
path |
string |
URI from which to load the input file containing the CIFS local users and groups. The file must be encrypted using the 7zip utility. URI can be FTP or HTTP. |
status_uri
path |
string |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
