Create an S3 group configuration
Creates an S3 group configuration to manage user access and policies within an SVM in ONTAP. This helps organize permissions and roles for users interacting with your S3 storage resources.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/groups
Introduced in
ONTAP 9.8
Important notes
Each SVM can have one or more s3 group configurations.
Required properties
svm.uuid- Existing SVM in which to create the user configuration. -
name- Group name that is to be created. -
users- List of users to be added into the group. -
policies- List of policies are to be attached to this group.
Recommended optional properties
comment- Short description about the S3 Group.
Related ONTAP commands
vserver object-store-server group create
Learn more
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
comment |
string |
Can contain any additional information about the group being created or modified. |
id |
integer |
Specifies a unique group ID used to identify a particular group. This parameter should not be specified in the POST method. A group ID is automatically generated and it is retrieved using the GET method. Group id is SVM scoped. |
name |
string |
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
policies |
array[policies] |
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies. |
svm |
users |
array[users] |
Specifies the list of users who belong to the group. |
Example request
"comment": "Admin group",
"id": 5,
"name": "Admin-Group",
"policies": [
"name": "Policy1"
"svm": {
"name": "svm1",
"users": [
"name": "user-1"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[s3_group] |
"num_records": 1,
"records": [
"id": 5,
"policies": [
"name": "Policy1"
"svm": {
"name": "svm1",
"users": [
"name": "user-1"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405896 |
Users list cannot be empty. |
92405930 |
Group name is not valid. Group names must have between 1 and 128 characters. |
92405931 |
Group name contains invalid characters. Valid characters for a group name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-". |
92405932 |
Creating an object store group requires an effective cluster version of 9.8 or later. |
92405933 |
Failed to create group for SVM. Reason: "{reason of failure}". |
92405934 |
User name specified in the user list do not exist for SVM. Use the "object-store-server user create" command to create a user. |
92405935 |
Internal Error. Unable to generate unique ID for the group. |
92405936 |
Query characters such as * are not supported in the user list. |
92405937 |
Policy name specified in the policy list do not exist for SVM. |
92405942 |
Group name already exists for SVM. |
262222 |
User name is present more than once in the users field. |
href |
string |
_links
policies
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm
name |
string |
The name of the SVM. |
uuid |
string |
users
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
s3_group
This is a container for S3 user groups.
comment |
string |
id |
integer |
name |
string |
policies |
array[policies] |
svm |
users |
array[users] |
collection_links
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
