Create an S3 group configuration
Creates an S3 group configuration to define and manage user groups and their associated policies within a Storage Virtual Machine (SVM). This operation helps you organize and control access to S3 resources effectively.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/groups
Introduced in
ONTAP 9.8
Important notes
Each SVM can have one or more s3 group configurations.
Required properties
svm.uuid- Existing SVM in which to create the user configuration. -
name- Group name that is to be created. -
users- List of users to be added into the group. -
policies- List of policies are to be attached to this group.
Recommended optional properties
comment- Short description about the S3 Group.
Related ONTAP commands
vserver object-store-server group create
Learn more
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
comment |
string |
Can contain any additional information about the group being created or modified. |
id |
integer |
Specifies a unique Group ID used to identify a particular group. This parameter should not be specified in the POST or PATCH method. A Group ID is automatically generated and it is retrieved using the GET method. Group ID is SVM-scoped. |
name |
string |
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
policies |
array[policies] |
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies. |
svm |
users |
array[users] |
Specifies the list of users who belong to the group. |
Example request
"comment": "Admin group",
"id": 5,
"name": "Admin-Group",
"policies": [
"name": "Policy1"
"svm": {
"name": "svm1",
"users": [
"name": "user-1"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[s3_group] |
"num_records": 1,
"records": [
"id": 5,
"policies": [
"name": "Policy1"
"svm": {
"name": "svm1",
"users": [
"name": "user-1"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405896 |
Users list cannot be empty. |
92405930 |
Group name "{group name}" is not valid. Group names must have between 1 and 128 characters. |
92405931 |
Group name "{group name}" contains invalid characters. Valid characters for a group name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-". |
92405932 |
Creating an object store group requires an effective cluster version of 9.8 or later. |
92405933 |
Failed to create group for SVM. Reason: "{reason of failure}". |
92405934 |
Users {user name} specified in the user list do not exist for SVM "{vserver name}". Use the "object-store-server user create" command to create a user. |
92405935 |
Internal Error. Unable to generate unique ID for the group. |
92405936 |
Query characters such as * are not supported in the user list. |
92405937 |
Policies {policy name} specified in the policy list do not exist for SVM "{vserver name}". |
92405942 |
Group name "{group name}" already exists for SVM "{vserver name}". |
92405858 |
Failed to "create" the "group" because the operation is only supported on data SVMs. |
262222 |
User name is present more than once in the users field. |
92406154 |
Users {user} specified in the user list do not exist for SVM "vs1". Use the "/protocols/s3/services/{svm.uuid}/users" endpoint to create a user. |
92406307 |
Cannot add object store user "user1" in SVM "vs1" to the group. Reason: The user is disabled, because it does not have keys generated. |
href |
string |
_links
policies
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm
name |
string |
uuid |
string |
users
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
s3_group
This is a container for S3 user groups.
comment |
string |
id |
integer |
name |
string |
policies |
array[policies] |
svm |
users |
array[users] |
collection_links
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
