REST API reference
Create an S3 group configuration
Configures a new S3 group within an existing SVM to manage user access and policies specific to that group. This can be useful when organizing users and permissions for S3 operations under a structured group setup.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/groups
Introduced in
ONTAP 9.8
Usage notes
Creates the S3 group configuration.
Important notes
  • Each SVM can have one or more s3 group configurations.
Required properties
  • svm.uuid - Existing SVM in which to create the user configuration.
  • name - Group name that is to be created.
  • users - List of users to be added into the group.
  • policies - List of policies are to be attached to this group.
  • comment - Short description about the S3 Group.
  • vserver object-store-server group create
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
comment
string
Can contain any additional information about the group being created or modified.
id
integer
Specifies a unique Group ID used to identify a particular group. This parameter should not be specified in the POST or PATCH method. A Group ID is automatically generated and it is retrieved using the GET method. Group ID is SVM-scoped.
name
string
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
policies
array[policies]
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies.
svm
svm
users
array[users]
Specifies the list of users who belong to the group.
Example request
  "comment": "Admin group",
  "id": 5,
  "name": "Admin-Group",
  "policies": [
      "name": "Policy1"
  "svm": {
    "name": "svm1",
  "users": [
      "name": "user-1"
Status: 201, Created
num_records
integer
Number of records
records
array[s3_group]
  "num_records": 1,
  "records": [
      "id": 5,
      "policies": [
          "name": "Policy1"
      "svm": {
        "name": "svm1",
      "users": [
          "name": "user-1"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
92405896
Users list cannot be empty.
92405930
Group name "{group name}" is not valid. Group names must have between 1 and 128 characters.
92405931
Group name "{group name}" contains invalid characters. Valid characters for a group name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-".
92405932
Creating an object store group requires an effective cluster version of 9.8 or later.
92405933
Failed to create group for SVM. Reason: "{reason of failure}".
92405934
Users {user name} specified in the user list do not exist for SVM "{vserver name}". Use the "object-store-server user create" command to create a user.
92405935
Internal Error. Unable to generate unique ID for the group.
92405936
Query characters such as * are not supported in the user list.
92405937
Policies {policy name} specified in the policy list do not exist for SVM "{vserver name}".
92405942
Group name "{group name}" already exists for SVM "{vserver name}".
92405858
Failed to "create" the "group" because the operation is only supported on data SVMs.
262222
User name is present more than once in the users field.
92406154
Users {user} specified in the user list do not exist for SVM "vs1". Use the "/protocols/s3/services/{svm.uuid}/users" endpoint to create a user.
string
policies
name
string
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
name
string
uuid
string
users
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
s3_group
This is a container for S3 user groups.
comment
string
id
integer
name
string
policies
array[policies]
svm
svm
users
array[users]
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
