REST API reference
Create an S3 group configuration
Creates an S3 group configuration to organize users and policies within a specific storage virtual machine (SVM). Use this endpoint to set up a new group with designated users and attach relevant policies, facilitating efficient management of S3 resources.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/groups
Introduced in
ONTAP 9.8
Important notes
  • Each SVM can have one or more s3 group configurations.
Required properties
  • svm.uuid - Existing SVM in which to create the user configuration.
  • name - Group name that is to be created.
  • users - List of users to be added into the group.
  • policies - List of policies are to be attached to this group.
  • comment - Short description about the S3 Group.
  • vserver object-store-server group create
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
comment
string
Can contain any additional information about the group being created or modified.
id
integer
Specifies a unique group ID used to identify a particular group. This parameter should not be specified in the POST method. A group ID is automatically generated and it is retrieved using the GET method. Group id is SVM scoped.
name
string
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
policies
array[policies]
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies.
svm
svm
users
array[users]
Specifies the list of users who belong to the group.
Example request
  "comment": "Admin group",
  "id": "5",
  "name": "Admin-Group",
  "policies": [
      "name": "Policy1"
  "svm": {
    "name": "svm1",
  "users": [
      "name": "user-1"
Status: 201, Created
num_records
integer
Number of records
records
array[s3_group]
  "records": [
      "id": "5",
      "policies": [
          "name": "Policy1"
      "svm": {
        "name": "svm1",
      "users": [
          "name": "user-1"
Status: Default
ONTAP Error Response Codes
Error Code Description
92405896
Users list cannot be empty.
92405930
Group name is not valid. Group names must have between 1 and 128 characters.
92405931
Group name contains invalid characters. Valid characters for a group name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-".
92405932
Creating an object store group requires an effective cluster version of 9.8 or later.
92405933
Failed to create group for SVM. Reason: "{reason of failure}".
92405934
User name specified in the user list do not exist for SVM. Use the "object-store-server user create" command to create a user.
92405935
Internal Error. Unable to generate unique ID for the group.
92405936
Query characters such as * are not supported in the user list.
92405937
Policy name specified in the policy list do not exist for SVM.
92405942
Group name already exists for SVM.
92405966
User name is present more than once in the users field.
string
policies
name
string
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
name
string
The name of the SVM.
uuid
string
users
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
s3_group
This is a container for S3 user groups.
comment
string
id
integer
name
string
policies
array[policies]
svm
svm
users
array[users]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
