Creates a new tag on a specific resource
POST /resource-tags/{resource_tag.value}/resources
Introduced In: 9.13
Creates a new tag on a specific resource.
resource_tag.value |
string |
path |
True |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
href |
string |
This property provides the address in the API at which the tagged resource is available. Additional queries can be made on this endpoint to fetch the resource's properties. |
Example request
"href": "string"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262257 |
The API specified in the href cannot be found. |
262258 |
The resource specified in the href does not support tagging. |
262259 |
The specified href cannot be parsed. |
262260 |
The provided href is missing a key to a specific resource. |
262261 |
The specified href points to a resource that does not exist. |
href |
string |
_links
svm
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned.
name |
string |
The name of the SVM. |
uuid |
string |
resource_tag_resource
This object provides a pointer to the tagged resource in the API. Details about the tagged object are available by querying the address of the href property.
href |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
