Create a new tag for a resource
POST /resource-tags/{resource_tag.value}/resources
Introduced In: 9.13
Creates a new tag on a specific resource.
resource_tag.value  |
string  |
path  |
True  |
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
href  |
string  |
This property provides the address in the API at which the tagged resource is available. Additional queries can be made on this endpoint to fetch the resource's properties.  |
label  |
string  |
This is a human-readable classifier representing the type of thing that is pointed to by the href.  |
svm  |
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned.  |
value  |
string  |
The text value of the tag formatted as   |
Example request
  "href": "string",
  "label": "volume",
  "svm": {
    "name": "svm1",
  "value": "string"
Status: 201, Created
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262257  |
The API specified in the href cannot be found.  |
262258  |
The resource specified in the href does not support tagging.  |
262259  |
The specified href cannot be parsed.  |
262260  |
The provided href is missing a key to a specific resource.  |
262261  |
The specified href points to a resource that does not exist.  |
262262  |
The specified href cannot be an empty string.  |
262263  |
Tag key-value pairs cannot be longer than 200 characters.  |
263148  |
Specified resource cannot be tagged because it reached allowed tags limit.  |
href  |
string  |
_links
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
resource_tag_resource
This object provides a pointer to the tagged resource in the API. Details about the tagged object are available by querying the address of the href property.
href  |
string  |
label  |
string  |
svm  |
value  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
