Create a new tag for a resource
Adds a new tag to a specific resource, which helps in organizing and managing resources more effectively within your environment.
HTTP method and endpoint
POST /resource-tags/{resource_tag.value}/resources
Introduced in
ONTAP 9.13
Usage notes
Creates a new tag on a specific resource.
resource_tag.value |
string |
path |
True |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
href |
string |
This property provides the address in the API at which the tagged resource is available. Additional queries can be made on this endpoint to fetch the resource's properties. |
label |
string |
This is a human-readable classifier representing the type of thing that is pointed to by the href. |
svm |
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned. |
Example request
"href": "string",
"label": "volume",
"svm": {
"name": "svm1",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262257 |
The API specified in the href cannot be found. |
262258 |
The resource specified in the href does not support tagging. |
262259 |
The specified href cannot be parsed. |
262260 |
The provided href is missing a key to a specific resource. |
262261 |
The specified href points to a resource that does not exist. |
262262 |
The specified href cannot be an empty string. |
262263 |
Tag key-value pairs cannot be longer than 200 characters. |
263148 |
Specified resource cannot be tagged because it reached allowed tags limit. |
href |
string |
_links
svm
name |
string |
uuid |
string |
resource_tag_resource
This object provides a pointer to the tagged resource in the API. Details about the tagged object are available by querying the address of the href property.
href |
string |
label |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
