REST API reference
Create a new tag for a resource
Adds a new tag to a specific resource, which helps in organizing and managing resources more effectively within your environment.
HTTP method and endpoint
POST /resource-tags/{resource_tag.value}/resources
Introduced in
ONTAP 9.13
Usage notes
Creates a new tag on a specific resource.
resource_tag.value
string
path
True
  • format: key:value
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
string
This property provides the address in the API at which the tagged resource is available. Additional queries can be made on this endpoint to fetch the resource's properties.
label
string
This is a human-readable classifier representing the type of thing that is pointed to by the href.
svm
svm
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned.
value
string
The text value of the tag formatted as key:value.
Example request
  "href": "string",
  "label": "volume",
  "svm": {
    "name": "svm1",
  "value": "string"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262257
The API specified in the href cannot be found.
262258
The resource specified in the href does not support tagging.
262259
The specified href cannot be parsed.
262260
The provided href is missing a key to a specific resource.
262261
The specified href points to a resource that does not exist.
262262
The specified href cannot be an empty string.
262263
Tag key-value pairs cannot be longer than 200 characters.
263148
Specified resource cannot be tagged because it reached allowed tags limit.
string
svm
name
string
uuid
string
resource_tag_resource
This object provides a pointer to the tagged resource in the API. Details about the tagged object are available by querying the address of the href property.
string
label
string
svm
svm
value
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
