REST API reference
Create an application log
Creates an application log event to generate specific event details for client applications. This can trigger AutoSupports if the autosupport_required flag is set, aiding in proactive system monitoring and support.
HTTP method and endpoint
POST /support/ems/application-logs
Introduced in
ONTAP 9.11
Usage notes
Creates an app.log.* event. Setting the "autosupport_required" flag causes callhome.client.app.* events also to be generated, which in turn triggers AutoSupports.
Required properties
  • computer_name - Client computer connected to the cluster.
  • event_source - Client application that generated this event.
  • app_version - Client application version.
  • event_id - Application eventID.
  • category - Event category.
  • event_description - Event description.
  • severity - Severity of the event.
  • autosupport_required - Indicates whether AutoSupport generation is required.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
app_version
string
boolean
category
string
Event category.
computer_name
string
event_description
string
Event description, which corresponds to the subject parameter in the generated event.
event_id
integer
event_source
string
severity
string
Severity
Example request
  "app_version": "3.0.0.2373",
  "autosupport_required": "",
  "category": "Error",
  "computer_name": "W12-R2-DC",
  "event_description": "Clone split job failed",
  "event_id": 10001,
  "event_source": "SnapCenter Software",
  "severity": "error"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
983146
Invalid value specified for the field "severity".
983173
Application log event generation failed.
ems_application_log
Input for generation of app.log.x and callhome.client.app.x events.
app_version
string
boolean
category
string
Event category.
computer_name
string
event_description
string
event_id
integer
event_source
string
severity
string
Severity
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
