Create an application log
POST /support/ems/application-logs
Introduced In: 9.11
Creates an app.log.* event. Setting the "autosupport_required" flag causes callhome.client.app.* events also to be generated, which in turn triggers AutoSupports.
Required properties
computer_name
- Client computer connected to the cluster. -
event_source
- Client application that generated this event. -
app_version
- Client application version. -
event_id
- Application eventID. -
category
- Event category. -
event_description
- Event description. -
severity
- Severity of the event. -
- Indicates whether AutoSupport generation is required.
Name | Type | In | Required | Description |
return_records |
boolean |
query |
False |
Request Body
Name | Type | Description |
app_version |
string |
Client application version. |
autosupport_required |
boolean |
Indicates whether AutoSupport generation is required. |
category |
string |
Event category. |
computer_name |
string |
Client computer connected to the cluster. |
event_description |
string |
Event description, which corresponds to the subject parameter in the generated event. |
event_id |
integer |
Application eventID. |
event_source |
string |
Client application that generated this event. |
severity |
string |
Severity |
Example request
"app_version": "3.0.0.2373",
"autosupport_required": "",
"category": "Error",
"computer_name": "W12-R2-DC",
"event_description": "Clone split job failed",
"event_id": 10001,
"event_source": "SnapCenter Software",
"severity": "error"
Status: 201, Created
Headers
Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
Error Code | Description |
983173 |
Application log event generation failed. |
ems_application_log
Input for generation of app.log.x and callhome.client.app.x events.
app_version |
string |
boolean |
category |
string |
Event category. |
computer_name |
string |
event_description |
string |
event_id |
integer |
event_source |
string |
severity |
string |
Severity |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
