Create an application log
POST /support/ems/application-logs
Introduced In: 9.11
Creates an app.log.* event. Setting the "autosupport_required" flag causes callhome.client.app.* events also to be generated, which in turn triggers AutoSupports.
Required properties
computer_name- Client computer connected to the cluster. -
event_source- Client application that generated this event. -
app_version- Client application version. -
event_id- Application eventID. -
category- Event category. -
event_description- Event description. -
severity- Severity of the event. -
autosupport_required- Indicates whether AutoSupport generation is required.
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
app_version  |
string  |
Client application version.  |
autosupport_required  |
boolean  |
Indicates whether AutoSupport generation is required.  |
category  |
string  |
Event category.  |
computer_name  |
string  |
Client computer connected to the cluster.  |
event_description  |
string  |
Event description, which corresponds to the subject parameter in the generated event.  |
event_id  |
integer  |
Application eventID.  |
event_source  |
string  |
Client application that generated this event.  |
severity  |
string  |
Severity  |
Example request
  "app_version": "3.0.0.2373",
  "autosupport_required": "",
  "category": "Error",
  "computer_name": "W12-R2-DC",
  "event_description": "Clone split job failed",
  "event_id": 10001,
  "event_source": "SnapCenter Software",
  "severity": "error"
Status: 201, Created
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983173  |
Application log event generation failed.  |
ems_application_log
Input for generation of app.log.x and callhome.client.app.x events.
app_version  |
string  |
boolean  |
category  |
string  |
Event category.  |
computer_name  |
string  |
event_description  |
string  |
event_id  |
integer  |
event_source  |
string  |
severity  |
string  |
Severity  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
