REST API reference
Create an application log
Creates an application log event, specifying details such as the client computer, application version, and event category. Use this operation to generate AutoSupport events when needed, enhancing system monitoring and troubleshooting.
HTTP method and endpoint
POST /support/ems/application-logs
Introduced in
ONTAP 9.11
Usage notes
Creates an app.log.* event. Setting the "autosupport_required" flag causes callhome.client.app.* events also to be generated, which in turn triggers AutoSupports.
Required properties
  • computer_name - Client computer connected to the cluster.
  • event_source - Client application that generated this event.
  • app_version - Client application version.
  • event_id - Application eventID.
  • category - Event category.
  • event_description - Event description.
  • severity - Severity of the event.
  • autosupport_required - Indicates whether AutoSupport generation is required.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
app_version
string
boolean
category
string
Event category.
computer_name
string
event_description
string
Event description, which corresponds to the subject parameter in the generated event.
event_id
integer
event_source
string
severity
string
Severity
Example request
  "app_version": "3.0.0.2373",
  "autosupport_required": "",
  "category": "Error",
  "computer_name": "W12-R2-DC",
  "event_description": "Clone split job failed",
  "event_id": 10001,
  "event_source": "SnapCenter Software",
  "severity": "error"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
983173
Application log event generation failed.
ems_application_log
Input for generation of app.log.x and callhome.client.app.x events.
app_version
string
boolean
category
string
Event category.
computer_name
string
event_description
string
event_id
integer
event_source
string
severity
string
Severity
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
