Security key-manager-configs endpoint overview
Overview
Retrieves or modifies the key management configuration options. The following operations are supported:
GET
PATCH
Retrieving cluster-level key manager configurations
The following example shows how to retrieve cluster-level manager configurations.
# The API:
GET /api/security/key-manager-configs
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json'
# The response:
"cc_mode_enabled": false,
"health_monitor_polling_interval": 15,
"cloud_kms_retry_count": 3,
"href": "/api/security/key-manager-configs"
Updating the cluster-level key manager configurations
The following example shows how to modify the "health_monitor_polling_interval" and "cloud_kms_retry_count" fields.
# The API:
PATCH /api/security/key-manager-configs
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d "{ \"health_monitor_polling_interval\" : \"20\", \"cloud_kms_retry_count\" : \"5\" }"
The following example shows how to modify the "cc_mode".
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d "{ \"cc_mode_enabled\" : \"true\", \"passphrase\": \"current_passphrase\" }"
