REST API reference
View and update key manager configurations
Access and modify key management configurations to optimize security settings within your ONTAP environment. Use these endpoints to retrieve current configurations or update settings such as health monitor policies and retry counts for cloud key management services.
Overview
Retrieves or modifies the key management configuration options. The following operations are supported:
  • GET
  • PATCH
Retrieving cluster-level key manager configurations
The following example shows how to retrieve cluster-level manager configurations.
# The API:
GET /api/security/key-manager-configs
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json'
# The response:
"cc_mode_enabled": false,
"health_monitor_polling_interval": 15,
"cloud_kms_retry_count": 3,
"health_monitor_policy": {
  "akv": {
    "enabled": true,
    "manage_volume_offline": true
  "gcp": {
    "enabled": true,
  "aws": {
    "enabled": true,
  "ikp": {
    "enabled": true,
  "okm": {
    "enabled": true,
  "kmip": {
    "enabled": true,
    "href": "/api/security/key-manager-configs"
Updating the cluster-level key manager configurations
The following example shows how to modify the "health_monitor_polling_interval" and "cloud_kms_retry_count" fields.
# The API:
PATCH /api/security/key-manager-configs
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d "{ \"health_monitor_polling_interval\" : \"20\", \"cloud_kms_retry_count\" : \"5\" }"
The following example shows how to modify the "cc_mode" and "passphrase" fields.
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d "{ \"cc_mode_enabled\" : \"true\", \"passphrase\": \"current_passphrase\" }"
Shows the keystore level health monitor policy
The following example shows how to retrieve the health monitor policies for Amazon Web Services and Google Cloud.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-manager-configs?fields=health_monitor_policy.aws,health_monitor_policy.gcp' -H 'accept: application/hal+json'
# The response:
  "gcp": {
    "enabled": false,
    "manage_volume_offline": false
  "aws": {
    "enabled": false,
Updates the keytore level health monitor policy
The following example shows how to modify the Amazon Web Services "enabled" field and the Google Cloud "manage_volume_offline" field of the health monitor policy.
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d '{"health_monitor_policy": {"aws": {"enabled": "false"}, "gcp": {"manage_volume_offline": "false"}}}'
