Security key-manager-configs endpoint overview
Overview
Retrieves or modifies the key management configuration options. The following operations are supported:
GET
PATCH
Retrieving cluster-level key manager configurations
The following example shows how to retrieve cluster-level manager configurations.
# The API:
GET /api/security/key-manager-configs
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json'
# The response:
"cc_mode_enabled": false,
"health_monitor_polling_interval": 15,
"cloud_kms_retry_count": 3,
"health_monitor_policy": {
  "akv": {
    "enabled": true,
    "manage_volume_offline": true
  "gcp": {
    "enabled": true,
  "aws": {
    "enabled": true,
  "ikp": {
    "enabled": true,
  "okm": {
    "enabled": true,
  "kmip": {
    "enabled": true,
    "href": "/api/security/key-manager-configs"
Updating the cluster-level key manager configurations
The following example shows how to modify the "health_monitor_polling_interval" and "cloud_kms_retry_count" fields.
# The API:
PATCH /api/security/key-manager-configs
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d "{ \"health_monitor_polling_interval\" : \"20\", \"cloud_kms_retry_count\" : \"5\" }"
The following example shows how to modify the "cc_mode" and "passphrase" fields.
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d "{ \"cc_mode_enabled\" : \"true\", \"passphrase\": \"current_passphrase\" }"
Shows the keystore level health monitor policy
The following example shows how to retrieve the health monitor policies for Amazon Web Services and Google Cloud.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-manager-configs?fields=health_monitor_policy.aws,health_monitor_policy.gcp' -H 'accept: application/hal+json'
# The response:
  "gcp": {
    "enabled": false,
    "manage_volume_offline": false
  "aws": {
    "enabled": false,
Updates the keytore level health monitor policy
The following example shows how to modify the Amazon Web Services "enabled" field and the Google Cloud "manage_volume_offline" field of the health monitor policy.
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d '{"health_monitor_policy": {"aws": {"enabled": "false"}, "gcp": {"manage_volume_offline": "false"}}}'
