REST API reference
Delete an FPolicy external engine configuration
Deletes an FPolicy external engine configuration when you need to remove an existing engine setup.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/engines/{name}
Introduced in
ONTAP 9.6
Usage notes
Deletion of an FPolicy engine that is attached to one or more FPolicy policies is not allowed.
  • fpolicy policy external-engine modify
name
string
path
True
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
9764940
At least one FPolicy policy is using the FPolicy engine
9764887
The FPolicy engine is a cluster level FPolicy engine
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
