Delete an FPolicy external engine configuration
Removes an FPolicy external engine configuration that is no longer needed. This action is useful when you want to clean up unused configurations from your system.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/engines/{name}
Introduced in
ONTAP 9.6
Usage notes
Deletes the FPolicy external engine configuration. Deletion of an FPolicy engine that is attached to one or more FPolicy policies is not allowed.
Related ONTAP commands
fpolicy policy external-engine modify
Learn more
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9764940 |
At least one FPolicy policy is using the FPolicy engine |
9764887 |
The FPolicy engine is a cluster level FPolicy engine |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
