Delete an FPolicy external engine configuration
Deletes an FPolicy external engine configuration when you need to remove an engine that is no longer required or has been replaced.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/engines/{name}
Introduced in
ONTAP 9.6
Usage notes
Deletion of an FPolicy engine that is attached to one or more FPolicy policies is not allowed.
Related ONTAP commands
fpolicy policy external-engine delete
Learn more
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9764940 |
At least one FPolicy policy is using the FPolicy engine |
9764887 |
The FPolicy engine is a cluster level FPolicy engine |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
