REST API reference
Delete an FPolicy external engine configuration
Deletes an FPolicy external engine configuration when you need to remove an engine that is no longer required or has been replaced.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/engines/{name}
Introduced in
ONTAP 9.6
Usage notes
Deletion of an FPolicy engine that is attached to one or more FPolicy policies is not allowed.
  • fpolicy policy external-engine delete
name
string
path
True
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
9764940
At least one FPolicy policy is using the FPolicy engine
9764887
The FPolicy engine is a cluster level FPolicy engine
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
