REST API reference
Retrieve the CIFS connection information for all SVMs
Retrieves CIFS connection information for all SVMs to assess and manage your CIFS network connections effectively.
HTTP method and endpoint
GET /protocols/cifs/connections
Introduced in
ONTAP 9.11
  • vserver cifs connection show
client_port
integer
query
False
Filter by client_port
identifier
integer
query
False
Filter by identifier
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
client_ip
string
query
False
Filter by client_ip
sessions.identifier
integer
query
False
Filter by sessions.identifier
network_context_id
integer
query
False
Filter by network_context_id
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
server_ip
string
query
False
Filter by server_ip
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_connection]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "client_ip": "10.74.7.182",
      "client_port": 12345,
      "identifier": 22802,
      "network_context_id": 22802,
      "node": {
        "name": "node1",
      "server_ip": "10.140.78.248",
      "sessions": [
          "identifier": 4622663542519103507
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
sessions
identifier
integer
A unique 64-bit unsigned number represented as string used to represent each SMB session's identifier.
svm
_links
_links
name
string
uuid
string
cifs_connection
client_ip
string
Specifies IP of the client.
client_port
integer
"A unique 32-bit unsigned number used to represent the port number of the connection".
identifier
integer
A unique 32-bit unsigned number used to represent each SMB session's connection ID.
network_context_id
integer
A unique 32-bit unsigned number used to represent each SMB session's network context ID.
node
node
server_ip
string
Specifies the IP address of the SVM.
sessions
array[sessions]
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
