Retrieve the CIFS connection information for all SVMs
Retrieves the CIFS connection information for all SVMs to monitor and manage active CIFS sessions across your storage environment.
HTTP method and endpoint
GET /protocols/cifs/connections
Introduced in
ONTAP 9.11
Related ONTAP commands
vserver cifs connection show
Learn more
client_ip |
string |
query |
False |
Filter by client_ip |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
network_context_id |
integer |
query |
False |
Filter by network_context_id |
identifier |
integer |
query |
False |
Filter by identifier |
sessions.identifier |
integer |
query |
False |
Filter by sessions.identifier |
client_port |
integer |
query |
False |
Filter by client_port |
server_ip |
string |
query |
False |
Filter by server_ip |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[cifs_connection] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"client_ip": "10.74.7.182",
"client_port": 12345,
"identifier": 22802,
"network_context_id": 22802,
"node": {
"name": "node1",
"server_ip": "10.140.78.248",
"sessions": [
"identifier": 4622663542519103507
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
sessions
identifier |
integer |
A unique 64-bit unsigned number represented as string used to represent each SMB session's identifier. |
svm
_links |
name |
string |
uuid |
string |
cifs_connection
client_ip |
string |
Specifies IP of the client. |
client_port |
integer |
"A unique 32-bit unsigned number used to represent the port number of the connection". |
identifier |
integer |
A unique 32-bit unsigned number used to represent each SMB session's connection ID. |
integer |
A unique 32-bit unsigned number used to represent each SMB session's network context ID. |
node |
server_ip |
string |
Specifies the IP address of the SVM. |
sessions |
array[sessions] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
