REST API reference
Retrieve CIFS connection information for all SVMs
Retrieves CIFS connection information for all SVMs to review active connections and manage network access.
HTTP method and endpoint
GET /protocols/cifs/connections
Introduced in
ONTAP 9.11
  • vserver cifs connection show
client_ip
string
query
False
Filter by client_ip
identifier
integer
query
False
Filter by identifier
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
client_port
integer
query
False
Filter by client_port
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
network_context_id
integer
query
False
Filter by network_context_id
sessions.identifier
integer
query
False
Filter by sessions.identifier
server_ip
string
query
False
Filter by server_ip
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_connection]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "client_ip": "10.74.7.182",
      "client_port": 12345,
      "identifier": 22802,
      "network_context_id": 22802,
      "node": {
        "name": "node1",
      "server_ip": "10.140.78.248",
      "sessions": [
          "identifier": 4622663542519103507
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
sessions
identifier
integer
A unique 64-bit unsigned number represented as string used to represent each SMB session's identifier.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
cifs_connection
client_ip
string
Specifies IP of the client.
client_port
integer
"A unique 32-bit unsigned number used to represent the port number of the connection".
identifier
integer
A unique 32-bit unsigned number used to represent each SMB session's connection ID.
network_context_id
integer
A unique 32-bit unsigned number used to represent each SMB session's network context ID.
node
node
server_ip
string
Specifies the IP address of the SVM.
sessions
array[sessions]
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
