Retrieve the CIFS connection information for all SVMs
Retrieves CIFS connection information for all storage virtual machines (SVMs), helping you understand and manage CIFS connections across your system.
HTTP method and endpoint
GET /protocols/cifs/connections
Introduced in
ONTAP 9.11
Usage notes
Retrieves the CIFS connection information for all SVMs.
Related ONTAP commands
vserver cifs connection show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
server_ip |
string |
query |
False |
Filter by server_ip |
network_context_id |
integer |
query |
False |
Filter by network_context_id |
identifier |
integer |
query |
False |
Filter by identifier |
client_ip |
string |
query |
False |
Filter by client_ip |
client_port |
integer |
query |
False |
Filter by client_port |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
sessions.identifier |
integer |
query |
False |
Filter by sessions.identifier |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[cifs_connection] |
"next": {
"href": "/api/resourcelink"
"records": [
"client_ip": "10.74.7.182",
"client_port": 12345,
"identifier": 22802,
"network_context_id": 22802,
"node": {
"name": "node1",
"server_ip": "10.140.78.248",
"sessions": [
"identifier": 4622663542519103507
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
sessions
identifier |
integer |
A unique 64-bit unsigned number represented as string used to represent each SMB session's identifier. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cifs_connection
client_ip |
string |
Specifies IP of the client. |
client_port |
integer |
"A unique 32-bit unsigned number used to represent the port number of the connection". |
identifier |
integer |
A unique 32-bit unsigned number used to represent each SMB session's connection ID. |
integer |
A unique 32-bit unsigned number used to represent each SMB session's network context ID. |
node |
server_ip |
string |
Specifies the IP address of the SVM. |
sessions |
array[sessions] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
