REST API reference
Update the OAuth 2.0 status
PATCH /security/authentication/cluster/oauth2
Introduced In: 9.14
Updates the OAuth 2.0 status.
  • security oauth2 modify
Request Body
Name Type Description
enabled
boolean
Indicates whether OAuth 2.0 is enabled or disabled globally. Default value is false.
Status: 200, Ok
Status: Default,
security_oauth2_global
enabled
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
