REST API reference
Update the OAuth 2.0 status
Updates the OAuth 2.0 status to adjust authentication configurations for your ONTAP environment. Use this endpoint when you need to modify OAuth 2.0 settings to align with security policies or compliance requirements.
HTTP method and endpoint
PATCH /security/authentication/cluster/oauth2
Introduced in
ONTAP 9.14
  • security oauth2 modify
Request Body
Name Type Description
enabled
boolean
Indicates whether OAuth 2.0 is enabled or disabled globally. Default value is false.
Status: 200, Ok
Status: Default,
security_oauth2_global
enabled
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
