Update the OAuth 2.0 status
PATCH /security/authentication/cluster/oauth2
Introduced In: 9.14
Updates the OAuth 2.0 status.
Related ONTAP commands
security oauth2 modify
Request Body
| Name | Type | Description |
enabled |
boolean |
Indicates whether OAuth 2.0 is enabled or disabled globally. Default value is false. |
Status: 200, Ok
Status: Default,
security_oauth2_global
enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
