Update the OAuth 2.0 status
Updates the OAuth 2.0 status to adjust authentication configurations for your ONTAP environment. Use this endpoint when you need to modify OAuth 2.0 settings to align with security policies or compliance requirements.
HTTP method and endpoint
PATCH /security/authentication/cluster/oauth2
Introduced in
ONTAP 9.14
Related ONTAP commands
security oauth2 modify
Request Body
| Name | Type | Description |
enabled |
boolean |
Indicates whether OAuth 2.0 is enabled or disabled globally. Default value is false. |
Status: 200, Ok
Status: Default,
security_oauth2_global
enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
