REST API reference
Retrieve an SVM peer relationship instance
Retrieves the details of an SVM peer relationship instance to understand the parameters and settings of the peer relationship.
HTTP method and endpoint
GET /svm/peers/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the SVM peer relationship instance.
  • vserver peer show
Example
Retrieves the parameters of an SVM peer relationship.
GET "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
Learn more
uuid
string
path
True
SVM peer relationship UUID
  • Introduced in: 9.7
fields
array[string]
query
False
Specify the fields to return.
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
_links
_links
applications
array[string]
A list of applications for an SVM peer relationship.
name
string
A peer SVM alias name to avoid a name conflict on the local cluster.
peer
peer
Details for a peer SVM object.
state
string
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relationship, PATCH the state to "suspended". To resume a suspended SVM peer relationship, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH.
svm
svm
Local SVM details
uuid
string
      "href": "/api/resourcelink"
  "applications": [
    "snapmirror",
    "lun_copy"
  "force": true,
  "name": "string",
  "peer": {
    "cluster": {
      "name": "cluster2",
      "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
    "svm": {
      "name": "svm1",
  "state": "peered",
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error codes Description
26345578
Internal error. Unable to retrieve local or peer SVM name.
9896086
Peer SVM name conflicts with one of the following: a peer SVM in an existing SVM peer relationship, a local SVM, or an IPSpace. Use the "name" property to uniquely specify the peer SVM alias name.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
cluster
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
peer
cluster
cluster
svm
svm
svm
Local SVM details
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
