REST API reference
Retrieve an SVM peer relationship instance
GET /svm/peers/{uuid}
Introduced In: 9.6
Retrieves the SVM peer relationship instance.
  • vserver peer show
Example
Retrieves the parameters of an SVM peer relationship.
GET "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
Learn more
uuid
string
path
True
SVM peer relationship UUID
  • Introduced in: 9.7
fields
array[string]
query
False
Specify the fields to return.
return_timeout
integer
query
False
  • Default value: 1
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
_links
_links
applications
array[string]
A list of applications for an SVM peer relationship.
name
string
A peer SVM alias name to avoid a name conflict on the local cluster.
peer
peer
Details for a peer SVM object.
state
string
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relationship, PATCH the state to "suspended". To resume a suspended SVM peer relationship, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH.
svm
svm
Local SVM details
uuid
string
      "href": "/api/resourcelink"
  "applications": [
    "snapmirror",
    "lun_copy"
  "force": true,
  "name": "string",
  "peer": {
    "cluster": {
      "name": "cluster2",
      "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
    "svm": {
      "name": "svm1",
  "state": "peered",
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error codes Description
26345578
Internal error. Unable to retrieve local or peer SVM name.
9896086
Peer SVM name conflicts with one of the following: a peer SVM in an existing SVM peer relationship, a local SVM, or an IPSpace. Use the "name" property to uniquely specify the peer SVM alias name.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
cluster
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
peer
cluster
cluster
svm
svm
svm
Local SVM details
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
