Retrieve an SVM peer relationship instance
GET /svm/peers/{uuid}
Introduced In: 9.6
Retrieves the SVM peer relationship instance.
Related ONTAP commands
vserver peer show
Example
Retrieves the parameters of an SVM peer relationship.
GET "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
Learn more
uuid  |
string  |
path  |
True  |
SVM peer relation UUID
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
return_timeout  |
integer  |
query  |
False  |
Status: 200, Ok
| Name | Type | Description |
_links  |
applications  |
array[string]  |
A list of applications for an SVM peer relation.  |
name  |
string  |
A peer SVM alias name to avoid a name conflict on the local cluster.  |
peer  |
Details for a peer SVM object.  |
state  |
string  |
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relation, PATCH the state to "suspended". To resume a suspended SVM peer relation, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH.  |
svm  |
Local SVM details  |
uuid  |
string  |
SVM peer relation UUID  |
      "href": "/api/resourcelink"
  "applications": [
    "snapmirror",
    "lun_copy"
  "name": "string",
  "peer": {
    "cluster": {
      "name": "cluster2",
      "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
    "svm": {
      "name": "svm1",
  "state": "peered",
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345578  |
Internal error. Unable to retrieve local or peer SVM name.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
cluster
_links  |
name  |
string  |
uuid  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
peer
cluster  |
svm  |
SVM, applies only to SVM-scoped objects.  |
svm
Local SVM details
_links  |
name  |
string  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
