Retrieve an SVM peer relationship instance
Retrieves the details of an SVM peer relationship instance to understand the parameters and settings of the peer relationship.
HTTP method and endpoint
GET /svm/peers/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the SVM peer relationship instance.
Related ONTAP commands
vserver peer show
Example
Retrieves the parameters of an SVM peer relationship.
GET "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
Learn more
uuid |
string |
path |
True |
SVM peer relationship UUID
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
applications |
array[string] |
A list of applications for an SVM peer relationship. |
name |
string |
A peer SVM alias name to avoid a name conflict on the local cluster. |
peer |
Details for a peer SVM object. |
state |
string |
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relationship, PATCH the state to "suspended". To resume a suspended SVM peer relationship, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH. |
svm |
Local SVM details |
uuid |
string |
SVM peer relationship UUID |
"href": "/api/resourcelink"
"applications": [
"snapmirror",
"lun_copy"
"force": true,
"name": "string",
"peer": {
"cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"svm": {
"name": "svm1",
"state": "peered",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345578 |
Internal error. Unable to retrieve local or peer SVM name. |
9896086 |
Peer SVM name conflicts with one of the following: a peer SVM in an existing SVM peer relationship, a local SVM, or an IPSpace. Use the "name" property to uniquely specify the peer SVM alias name. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
peer
cluster |
svm |
svm
Local SVM details
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
