Manage the EMS event catalog
Access the EMS event catalog to retrieve detailed information about system-supported events, including descriptions, reasons for occurrences, and corrective actions. Use these endpoints to monitor and address event-related issues efficiently.
Overview
Allows access to the EMS event catalog. The catalog contains a list of all events supported by the system and their corresponding descriptions, the reason for an event occurrence, and how to correct issues related to the event.
Example
Querying for the first event that has a message name beginning with 'C'
# The API:
GET /api/support/ems/messages
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/messages?fields=name&max_records=1&name=C*" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
"name": "CR.Data.File.Inaccessible",
"href": "/api/support/ems/messages/CR.Data.File.Inaccessible"
"num_records": 1,
"href": "/api/support/ems/messages?fields=name&max_records=1&name=C*"
