Manage the EMS event catalog
Access the EMS event catalog to review system-supported events, their descriptions, causes, and corrective actions. Use these endpoints to query and understand event occurrences within your environment.
Overview
Allows access to the EMS event catalog. The catalog contains a list of all events supported by the system and their corresponding descriptions, the reason for an event occurrence, and how to correct issues related to the event.
Example
Querying for the first event that has a message name beginning with 'C'
# API
GET /api/support/ems/messages?fields=name&max_records=1&name=C*
# Response
200 OK
# JSON Body
"records": [
"name": "CR.Data.File.Inaccessible",
"href": "/api/support/ems/messages/CR.Data.File.Inaccessible"
"num_records": 1,
"href": "/api/support/ems/messages?fields=name&max_records=1&name=C*"
