REST API reference
Manage the EMS event catalog
Access the EMS event catalog to retrieve detailed information on system-supported events, including descriptions, reasons for occurrences, and corrective actions.
Overview
Allows access to the EMS event catalog. The catalog contains a list of all events supported by the system and their corresponding descriptions, the reason for an event occurrence, and how to correct issues related to the event.
Example
Querying for the first event that has a message name beginning with 'C'
# The API:
GET /api/support/ems/messages
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/messages?fields=name&max_records=1&name=C*" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
    "name": "CR.Data.File.Inaccessible",
        "href": "/api/support/ems/messages/CR.Data.File.Inaccessible"
"num_records": 1,
    "href": "/api/support/ems/messages?fields=name&max_records=1&name=C*"
