Manage the EMS event catalog
Access the EMS event catalog to retrieve a comprehensive list of supported system events along with their descriptions, reasons for occurrence, and corrective actions. Use these endpoints to query and investigate specific events to enhance system troubleshooting and support.
Overview
Allows access to the EMS event catalog. The catalog contains a list of all events supported by the system and their corresponding descriptions, the reason for an event occurrence, and how to correct issues related to the event.
Example
Querying for the first event that has a message name beginning with 'C'
# The API:
GET /api/support/ems/messages
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/messages?fields=name&max_records=1&name=C*" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
"name": "CR.Data.File.Inaccessible",
"href": "/api/support/ems/messages/CR.Data.File.Inaccessible"
"num_records": 1,
"href": "/api/support/ems/messages?fields=name&max_records=1&name=C*"
