Delete an audit configuration
DELETE /protocols/audit/{svm.uuid}
Deletes an audit configuration.
Related ONTAP commands
vserver audit disable -
vserver audit delete
Learn more
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202.  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9699349  |
Auditing should be disabled before deleting the audit configuration  |
9699350  |
Audit configuration cannot be deleted, final consolidation is in progress  |
9699410  |
Failed to disable multiproto.audit.evtxlog.support support capability  |
9699430  |
Failed to disable multiproto.audit.cifslogonlogoff.support support capability  |
9699433  |
Failed to disable multiproto.audit.capstaging.support support capability  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
