Update the AutoSupport configuration for an entire cluster
PATCH /support/autosupport
Introduced In: 9.6
Updates the AutoSupport configuration for the entire cluster.
Related ONTAP commands
system node autosupport modify
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
contact_support |
boolean |
Specifies whether to send the AutoSupport messages to vendor support. |
enabled |
boolean |
Specifies whether the AutoSupport daemon is enabled. When this setting is disabled, delivery of all AutoSupport messages is turned off. |
from |
string |
The e-mail address from which the AutoSupport messages are sent. To generate node-specific 'from' addresses, enable '-node-specific-from' parameter via ONTAP CLI.
is_minimal |
boolean |
Specifies whether the system information is collected in compliant form, to remove private data or in complete form, to enhance diagnostics. |
issues |
array[autosupport_issues] |
A list of nodes in the cluster with connectivity issues to HTTP/SMTP/AOD AutoSupport destinations along with the corresponding error descriptions and corrective actions. |
mail_hosts |
array[string] |
The names of the mail servers used to deliver AutoSupport messages via SMTP. |
partner_addresses |
array[string] |
The list of partner addresses. |
proxy_url |
string |
Proxy server for AutoSupport message delivery via HTTP/S. Optionally specify a username/password for authentication with the proxy server. |
to |
array[string] |
The e-mail addresses to which the AutoSupport messages are sent. |
transport |
string |
The name of the transport protocol used to deliver AutoSupport messages. |
Example request
"contact_support": 1,
"enabled": 1,
"from": "postmaster@example.com",
"is_minimal": 1,
"issues": [
"corrective_action": {
"code": "53149746",
"message": "Check the hostname of the SMTP server"
"issue": {
"code": "53149746",
"message": "SMTP connectivity check failed for destination: mailhost. Error: Could not resolve host - 'mailhost'"
"node": {
"name": "node1",
"mail_hosts": [
"mailhost1.example.com",
"mailhost2.example.com"
"partner_addresses": [
"user1@partner.com",
"user2@partner.com"
"proxy_url": "https://proxy.company.com",
"to": [
"user1@example.com",
"user2@example.com"
"transport": "smtp"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8650862 |
The SMTP mail host provided cannot be empty |
8650863 |
A maximum of 5 SMTP mail hosts can be provided |
8650864 |
A maximum of 5 email addresses can be provided |
8650865 |
A maximum of 5 partner email addresses can be provided |
53149727 |
The proxy URI provided is invalid |
53149728 |
The mailhost URI provided is invalid |
autosupport_connectivity_corrective_action
code |
string |
Corrective action code |
message |
string |
Corrective action message. The corrective action might contain commands which needs to be executed on the ONTAP CLI.
autosupport_connectivity_issue
code |
string |
Error code |
message |
string |
Error message |
href |
string |
_links
node
name |
string |
uuid |
string |
autosupport_issues
corrective_action |
issue |
node |
autosupport
contact_support |
boolean |
enabled |
boolean |
from |
string |
is_minimal |
boolean |
issues |
mail_hosts |
array[string] |
partner_addresses |
array[string] |
proxy_url |
string |
to |
array[string] |
transport |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
