Set up a MetroCluster configuration
POST /cluster/metrocluster
Introduced In: 9.8
Sets up a MetroCluster.
Required properties
partner_cluster.name -
dr_pairs
Recommended optional properties
mediator.*
Learn more
Related ONTAP commands
metrocluster configuration-settings dr-group create -
metrocluster configuration-settings interface create -
metrocluster configuration-settings connection connect -
metrocluster configuration-settings mediator add -
storage aggregate create -
storage aggregate mirror -
metrocluster configure
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
dr_pairs |
array[dr_pairs] |
DR Pairs to create as part of a MetroCluster configure. |
enabled |
boolean |
local |
mediator |
Mediator information |
partner_cluster |
Partner cluster information. |
remote |
Example request
"dr_pairs": [
"node": {
"name": "nodeA"
"partner": {
"name": "nodeB"
"local": {
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"mode": "string"
"mediator": {
"ip_address": "10.10.10.7",
"password": "mypassword",
"peer_cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"port": "31784",
"reachable": 1,
"user": "myusername",
"uuid": "string"
"partner_cluster": {
"name": "cluster2"
"remote": {
"cluster": {
"name": "cluster1",
"mode": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
href |
string |
self_link
node
Local node of the DR Group.
name |
string |
Name of the node. |
partner
Partner node of the DR Group.
name |
string |
Name of the node. |
dr_pairs
node |
Local node of the DR Group. |
partner |
Partner node of the DR Group. |
_links
cluster
name |
string |
uuid |
string |
local
cluster |
configuration_state |
string |
Indicates the state of the local cluster configuration. |
mode |
string |
Specifies the mode of operation of the local cluster. |
partner_cluster_reachable |
boolean |
Specifies whether the partner cluster is reachable from the local cluster. |
periodic_check_enabled |
boolean |
Indicates whether or not a periodic check is enabled on the local cluster. |
peer_cluster
The peer cluster that the mediator service is used for.
name |
string |
uuid |
string |
mediator
ip_address |
string |
The IP address of the mediator. |
password |
string |
The password used to connect to the REST server on the mediator. |
peer_cluster |
The peer cluster that the mediator service is used for. |
port |
integer |
The REST server's port number on the mediator. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
user |
string |
The username used to connect to the REST server on the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
partner_cluster
name |
string |
Name of the partner cluster. |
remote
cluster |
string |
Indicates the state of the remote cluster configuration. |
mode |
string |
Specifies the mode of operation of the remote cluster. |
metrocluster
Holds MetroCluster status and configuration parameters for the local and remote clusters. REST: /api/cluster/metrocluster
dr_pairs |
array[dr_pairs] |
enabled |
boolean |
local |
mediator |
partner_cluster |
remote |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
