Retrieve security certificates
Retrieves security certificates to view the existing certificates for secure communications.
HTTP method and endpoint
GET /security/certificates/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
security certificate show
uuid |
string |
path |
True |
Certificate UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
authority_key_identifier |
string |
Provides the key identifier of the issuing CA certificate that signed the SSL certificate. |
azure |
ca |
string |
Certificate authority |
common_name |
string |
FQDN or custom common name. Provide on POST when creating a self-signed certificate. |
expiry_time |
string |
Certificate expiration time, in ISO 8601 duration format or date and time format. Can be provided on POST if creating self-signed certificate. The expiration time range is between 1 day to 10 years. |
hash_function |
string |
Hashing function. Can be provided on POST when creating a self-signed certificate. Hash functions md5 and sha1 are not allowed on POST. |
key_size |
integer |
Key size of requested Certificate in bits. One of 512, 1024, 1536, 2048, 3072. Can be provided on POST if creating self-signed certificate with a minimum permissible value of 2048. |
name |
string |
Certificate name or name of the certificate to be downloaded from the Azure Key Vault (AKV). If not provided in POST, a unique name specific to the SVM is automatically generated. |
public_certificate |
string |
Public key Certificate in PEM format. If this is not provided in POST, a self-signed certificate is created. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
serial_number |
string |
Serial number of certificate. |
subject_alternatives |
subject_key_identifier |
string |
Provides the key identifier used to identify the public key in the SSL certificate. |
svm |
type |
string |
Type of Certificate. The following types are supported:
uuid |
string |
Unique ID that identifies a certificate. |
"href": "/api/resourcelink"
"authority_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D7",
"azure": {
"verify_host": true
"ca": "string",
"common_name": "test.domain.com",
"expiry_time": "2030-01-25 11:20:13 +0000",
"hash_function": "string",
"key_size": 512,
"name": "string",
"public_certificate": "<CERTIFICATE-CONTENT>",
"scope": "string",
"serial_number": "string",
"subject_alternatives": {
"dns": [
"*.example.com"
"email": [
"abc@example.com"
"ip": [
"10.225.34.10"
"uri": [
"http://example.com"
"subject_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D8",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
proxy
azure
proxy |
dns |
array[string] |
A list of DNS names for Subject Alternate name extension. |
array[string] |
A list of email addresses for Subject Alternate name extension |
ip |
array[string] |
A list of IP addresses for Subject Alternate name extension. |
uri |
array[string] |
A list of URIs for Subject Alternate name extension. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
