ONTAP ONTAPI-to-REST mapping
cluster-switch
cluster-switch-configure-health-monitor
This ONTAPI call does not have an equivalent REST API call.
cluster-switch-create
cluster-switch-delete
cluster-switch-get-iter
GET /api/network/ethernet/switches
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
address
address
device
name
is-monitoring-enabled-operational
monitoring.monitored
model
model
node
No REST Equivalent
reason
monitoring.reason
serial-number
serial_number
sw-version
version
type
network
version-source
No REST Equivalent
max-records
max_records
Specifies the maximum number of records to return before paging.
cluster-switch-modify
PATCH /api/network/ethernet/switches
address
address
community-or-username
snmp.user
device
No REST Equivalent
is-monitoring-enabled-admin
monitoring.enabled
model
No REST Equivalent
snmp-version
snmp.version
type
No REST Equivalent
cluster-switch-poll-get
cluster-switch-poll-modify
