ONTAP ONTAPI-to-REST mapping
cluster-switch
cluster-switch-configure-health-monitor
POST /api/cluster/software/download
Note: Alternatively, the SHM configuration file can be uploaded to the cluster with a POST request on /api/cluster/software/upload.
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
node
No REST Equivalent
The SHM configuration file is downloaded on all nodes in the cluster.
package-url
url
cluster-switch-create
POST /api/network/ethernet/switches
address
address
community-or-username
snmp.user
device
name
is-monitoring-enabled-admin
monitoring.enabled
model
model
snmp-version
snmp.version
type
network
cluster-switch-delete
DELETE /api/network/ethernet/switches/{name}
device
name
force
No REST Equivalent
cluster-switch-get-iter
GET /api/network/ethernet/switches
address
address
device
name
is-monitoring-enabled-operational
monitoring.monitored
model
model
node
No REST Equivalent
reason
monitoring.reason
serial-number
serial_number
sw-version
version
type
network
version-source
No REST Equivalent
max-records
max_records
Specifies the maximum number of records to return before paging.
cluster-switch-modify
PATCH /api/network/ethernet/switches/{name}
address
address
snmp.user
device
No REST Equivalent
monitoring.enabled
model
No REST Equivalent
snmp-version
snmp.version
type
No REST Equivalent
cluster-switch-poll-get
This ONTAPI call does not have an equivalent REST API call.
cluster-switch-poll-modify
