cluster-switch
cluster-switch-configure-health-monitor
POST /api/cluster/software/download
Note: Alternatively, the SHM configuration file can be uploaded to the cluster with a POST request on /api/cluster/software/upload.
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
node |
No REST Equivalent |
The SHM configuration file is downloaded on all nodes in the cluster. |
package-url |
url |
cluster-switch-create
POST /api/network/ethernet/switches
address |
address |
community-or-username |
snmp.user |
device |
name |
is-monitoring-enabled-admin |
monitoring.enabled |
model |
model |
snmp-version |
snmp.version |
type |
network |
cluster-switch-delete
DELETE /api/network/ethernet/switches/{name}
device |
name |
force |
cluster-switch-get-iter
GET /api/network/ethernet/switches
address |
address |
device |
name |
is-monitoring-enabled-operational |
monitoring.monitored |
model |
model |
node |
reason |
monitoring.reason |
serial-number |
serial_number |
sw-version |
version |
type |
network |
version-source |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
cluster-switch-modify
PATCH /api/network/ethernet/switches/{name}
address |
address |
snmp.user |
device |
model |
snmp-version |
snmp.version |
type |
cluster-switch-poll-get
This ONTAPI call does not have an equivalent REST API call.
cluster-switch-poll-modify
